Heat transfer analysis of an aluminium sheet
I am trying to model the heat trasfer in a square Aliminuim sheet. Heat is applied to the sheat from a heater block that is attatched to the Aliminuim sheet in the middle. The power from the heater is 150 W and the sheet is initially at room temperature.I'm not sure about a few things:
1) When I create a step , do I choose General heat transfer as the procedure type? And to define the steps do I choose transient or steady-state?
do I define the initial temperature of the mould?
2) What type of loading do I need to use?
3) How do I apply the heat flux in the middle of the sheet? A surface load? I tried to apply a surface load on the surface of the section of the sheet where the heater is attatched but that didn't work and had to apply body forces!
I am desperate for answers. Thank you very much!
RE: Heat transfer analysis of an aluminium sheet
corus
NO VALID RADIATION OUTPUT REQUESTS HAVE BEEN GENERATED. THIS MAY BE DUE TO EARLIER INPUT ERRORS OR SPECIFICATION OF A NONEXISTANT CAVITY OR SURFACE NAME
Do you know what it is implying?
corus
Thanks!
