Ethylene Glycol for Heating
We use ethylene glycol for our heat tracing. The boiler that we use for heating the glycol was re-tubed two years ago, and it just started leaking 3 months ago. Upon inspection, we found several tubes corroded around the area on the tube attached to the tube sheet(they're attached by rolling). We had an analysis done on the failed tubes and found a high level of Phosphorous, Potassium and Calcium in the corroded tubes. Does anyone have any ideas on sources of these metals? The boiler operated for almost 30 years before being re-tubed the first time, and nothing has changed in the operation since then, so I don't see why corrosion would set in so fast.
RE: Ethylene Glycol for Heating
Does your process consist of those compounds?
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
Recently receive new shipment of EG?
