Dielectric Compounds
Gentlemen:
Hopefully this is the right place for this-------I have been struggling with coming up with a plausible explanation (in layman terms) as to defining a particular trait that dielectrics or "near" dielectrics" seem to possess when applied in-between, or on to electrically conductive materials (in this case, I am referring to electrical terminals or metal threaded connections)
QUESTION: Why do most any common petroleum or synthetic based dielectric (or "near" dielectric)  compounds (from common lithium grease, many pipe dopes, silicone based dielectric greases and even #2 diesel) seem to exhibit the quality of a perfect dielectric compound when tested with a typical DVM,  or at lower AC or DC voltages (maybe up to 300V ?)  , and yet when put in-between two electrical terminals / connections,  or other mechanical connections ( treaded, bolted, etc) , the insulating properties of the compound disappear completely and in general use,  seems to make for a better electrical connection??
Is this a phenomenon that that has been discussed in the past in a semi-technical fashion,  but I cannot find a reference to? I believe there are many misconceptions about this subject as to how could a dielectric do anything but weaken the connection or insulate two surfaces. A very common example of this property is one you may have under the hood of your car is a WIF (water if fuel)  sensor circuit that is part of the fuel filter system on your Dodge, BMW, etc.,  diesel engine. The probe is immersed in #2 (a "near" dielectric) , but as soon as water is present, the probes complete the circuit although #2 is still in the mix and still coating the probes.. The reason I mention this particular example is because we are current developing a "universal" WIF circuit instrument that can be easily adapted to aftermarket uses.
A few years ago I wrote a small piece for a marine forum on the subject, but I am still not happy with my thoughts and explanations on the subject– a small excerpt:
Dielectric compounds (greases and the like) are used in most connections to help maintain a good electrical contact which is established by the mechanical connection of two or more pieces, whether it be a fixed connection or a switched/sliding contact connection.
To put it another way, always use non-reactive, non-conducting, moisture displacing dielectric greases or lubricants when making electrical connections. These "moisture displacers" prevent moisture and oxygen present in the environment from contacting the metal surfaces of electrical contacts, thereby limiting corrosion and preventing the buildup of resistance within the connection. The basic principle used here is the  "exclusion principle" and simply put, it is using a material (a dielectric grease or lubricant in this case) to occupy all of the spaces near and around an electrical connector that could otherwise be occupied by contaminants (possibly conductive) or moisture.
 Is there anyone out there that would care to share some thoughts on this subject or steer me to some reference material that would cater to the less formally educated on the subject?
Thanks, Tony
Tony Athens
http://www.sbmar.com
RE: Dielectric Compounds
Your description sounds great to me.
The only additional thing I can think of is that a high dielectric material (whatever that might be) might facilitate or contribute to galvanic action between dissimilar materials, whereas a low dielectric 'grease' is a barrier to galvanic action in the presence of moisture.
Dan
One of the reasons this material is used is to modify the connector insertion force per the vehicle manufacturer's requirements.
NYE is a major supplier of electrical compounds and has engineering guides on their Web site:
http://www.nyelubricants.com/autoengineering.htm
