Modal analysis after contact
Dear All,
I am running an analysis where two surfaces contact, then are bonded on contact. This seems to be perfectly possible in Ansys. What I would then like to do is run a modal analysis on the bonded assembly, by a restart. Does anyone know if it is possible or impossible to do this? I have a suspicion that it might not be possible... :S
Will
RE: Modal analysis after contact
You may be able to use the UPGEOM command to obtain the deformed geometry and then "tie" the surfaces together. The tie will need to be a linear contact condition for it to work in the modal analysis.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Thanks, I am still battling with the original contact analysis but that looks promising. Did you mean to "tie" the surfaces with rigid MPC elements for example?
