Standard flange weight
I am working on a small project to check the weight of a heatexchanger and found that the STD falange weight in the compress is not the same as the number listed in other resource like http://www.thermometricscorp.com/flan600weig.html
For example: any WN flanges larger than 14" 600# weight are lighter than number listed above.
Tom, Could you check it for me?
RE: Standard flange weight
Then there is the question "does the weight reported by COMPRESS include bolts?", I'm not certain of the answer to that one, off-hand. I used to know, but I tend to forget these details (and they may even change over time, software does progress; which makes it even more confounding for my memory).
We likely need to document this in our website Knowledgebase so that I don't have to keep reviewing this every couple of years.
Anyway, we will take another look at this issue and see what, if anything needs to be tidied up. ...and well documented!
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
