Using Solver in VBA
Using Solver in VBA
Using Solver in VBA
I'm trying to make a macro that will be able to me the amount of damage causes by a flood in a certain area but it doesn't work. Can't anyone find the problem?
Sub SolveurHauteur()
Dim i As Integer, s As String
    '   Paramètre de base
    debit = "$H$33"
For i = 43 To 47 Step 1
    s = Format(i, "0")
    '   Paramètre du solveur
    '   1. SetCell = Cellule cible
    '   2. MaxMinVal 1(max), 2(min), 3(égale à une valeur)
    '   3. ValueOf = La valeur (si MaxMinVal=3)
    '   4. ByChange = Cellule variable
    SolverOk SetCell:="$L$" + s, MaxMinVal:=3, ValueOf:=debit, ByChange:="$H$" + s
    '   Contrainte du solveur
    '   1. CellRef = Cellule ayant la contrainte
    '   2. Relation= 1(<=), 2(=), 3(>=), 4(nombre entier), 5(nombre binaire de zero ou un
    '   3. FormulaText = La valeur de la contrainte
    SolverAdd CellRef:="$H$" + s, Relation:=3, FormulaText:="0"
    '   Résoudre le solveur
    SolverSolve userFinish:=True
    SolverReset
    Next i
End Sub
RE: Using Solver in VBA
The "Engineering Spreadsheets" forum has heaps on the Solver.  Search it.  It that fails, re-ask your question in that forum.  But do everyone (including yourself) a favour and explain in your question in what way your attempt "doesn't work".
[My first guess:  you haven't added a "reference" to the Solver in your VBA environment.]
