If part changes rev is the assemblies change rev as well???
Hello all,
I've been looking all over the forum regarding this question and probably I wasn't looking hard enough, because I couldn't find a satisfactory answer.
To give you some background...
There is no MRP or PDM system in place. The files are saved with a different revision at the end (123R1 to 123R2). Sequential numbers, with no meaning.
We are implementing a new part numbering scheme at the company, with some intelligence to the numbers and we are striving to go to a MRP and PDME.
My question is: if you change a rev to a part used in 200 assemblies, are these 200 assemblies changes rev as well??? (part is not changing form, fit or function).
From PDME stand point, if you change the part and you open an assembly where that part is used, PDM will detect a change in the assembly and will want to bump the rev.
My problem is that you will get to a point that you will loose track of where you used part 123R1 and 123R2 or this is not relevant at all...
Thank you!
C
Thank you!
C
RE: If part changes rev is the assemblies change rev as well???
Otherwise, I don't think it would be necessary, especially if your PDME tracks it for you.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
But if you have PDME managing the files and you open the assembly with the latest revision to all the parts, then even if you don't change the assembly, wouldn't PDM see that assembly as modified?
From a CAD point of view, this is I believe why some systems have a distinction between revision and version, version ticks up every time it's saved (or it may be every time it's checked in, can't recall) but revisions are 'hard changes' implemented by the user.
As Pete says, it may be appropriate to leave the rev out of the file name (especially for models rather than drawings) and rely on file properties/meta data of the files.
Also, while it's not your question as such - I'd think twice before going from a dumb numbering system to a smart one. General concensus is that dumb numbering schemes are more robust and cause less problems than intelligent ones. There are several threads about this on this site and I think even a link to a formal report about it.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
What is considered a "significant" change, however, depends highly on your application. For example, if a change is paint only changes the color, this is probably not significant, but if a paint change implements a paint with a flame retardant additive, then that is most definitely significant.
Typically these are the types of questions that a Change Control Board (CCB) would consider before allowing a change to be processed. CCB systems and MRP systems should go hand-in-hand.
For the next higher assembly, we used to revise them up until the difference could not be seen graphically. Adding a hole in a bracket, would change the NHA, no matter what was shown. The next assembly would be revised only if the new hole changed any of the drawing views.
Ben Loosli
ASME Y14.100-2004 paragraph 6.8.1 explains in detail. I don't think it uses the 'form, fit, function' definition anywhere.
KENAT,
