Rainwater pipe in wall
I have an internal open plantwell with a 100mm pipe disappearing through a wall at floor level (fall unknown!). This pipe i think then bends vertically down and drops down a riser.
Can anyone advise on the calculation required to work out how much water this pipe will remove?
Lee
RE: Rainwater pipe in wall
Pipe flow according to Bernoulli.
At constant velocity,
Z + P1/γ/H1 - HL = Z + P2/γ/H2
Use any appropriate flow equation to calculate Head Loss, HL.
Reduce the flow by some appropriate amount that depends on if there is a screen or grating or some other entry conditions for the water going into the pipe.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
