Excel formula for hole array
Hello folks
Here is what I'm trying to do.
I have a cabinet partition or a cabinet side wall slab that I want to drill a series of holes 32mm apart in a single line.
I am able to do this using the array. I have turned the array into an I-feature and it works beautifully. But all the holes are either on or off.
I would like to be able to select individually just the holes I want or don't want to use on the part.
There are a total of 77 holes so I don't want to dimension them separately.
I'd like to try doing this on an excel spread sheet if possible.
Is there a formula that can do this?
Is this a practical way to go?
George
George
