Stainless and Airborne Sodium Chloride 'Dust'
I have a project where electrical cable trays are supported on unistrut type channels and the client has found that stainless steel S316 is recommended.
I've heard that S316 doesn't hold up well to chlorides. What would be the common stainless steel to use for airborne salt dust?
Dik
Dik
RE: Stainless and Airborne Sodium Chloride 'Dust'
As long as moisture is not present nor any condensation that could wet the chlorides, the 316 stainless should be acceptable.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
If for any reasons higher humidity and water vapours takes place;
this exposure may lead to sever impacts of corrosion even at time un-noticed(practically hidden beneath the cables)
Best Regards
Qalander(Chem)
it depends on the type of atmosphere where the SS is used. is a marine, industrial, desert..?
have a look at this software and docs.
htt
S
Corrosion Prevention & Corrosion Control
Dik
It is also less expensive than 316.
www.outokumpu.com
Plymouth Tube
