Extract properties from a .product
Hello:
I'd like to know how it would be the script code for extract the properties of the parts inside the product to a .txt file.
I could obtain the code for extracting parameters of single parts, but I need to get all of them in the hole product.
Can anyone help me?
I put above my code.
Sub CATMain()
Dim partDoc As PartDocument
Set partDoc = CATIA.ActiveDocument
Dim partProd As Product
Set partProd = partDoc.Product
Dim prodProps As Parameters
Set prodProps = partProd.UserRefProperties
Dim catParmP0 As Parameter
Set catParmP0 = prodProps.Item("P0")
Dim catParmP1 As Parameter
Set catParmP1 = prodProps.Item("P1")
Dim catParmP2 As Parameter
Set catParmP2 = prodProps.Item("P2")
Dim catParmP5 As Parameter
Set catParmP5 = prodProps.Item("P5")
Dim catParmP6 As Parameter
Set catParmP6 = prodProps.Item("P6")
Dim catParmP7 As Parameter
Set catParmP7 = prodProps.Item("P7")
Dim catParmP9 As Parameter
Set catParmP9 = prodProps.Item("P9")
Dim catParmP11 As Parameter
Set catParmP11 = prodProps.Item("P11")
Dim catParmP13 As Parameter
Set catParmP13 = prodProps.Item("P13")
Dim catParmP15 As Parameter
Set catParmP15 = prodProps.Item("P15")
' GUARDAR EN BLOC DE NOTAS
Dim filename As String
filename = CATIA.FileSelectionBox("Donde quiere guardar el fichero de resultado", "*.txt", CatFileSelectionModeSave)
Set Datos = CATIA.FileSystem.CreateFile(partProd.Name & ".fre" , True)
Set ostream = Datos.OpenAsTextStream("ForAppending")
ostream.Write ("P0=K") & catParmP0.Value & (" P1=K") & catParmP1.Value & (" P2=K") & catParmP2.Value & (" P5=K") & catParmP5.Value & (" P6=K") & catParmP6.Value & (" P7=K") & catParmP7.Value & (" P9=K") & catParmP9.Value& (" P11=K") & catParmP11.Value & (" P13=K") & catParmP13.Value & (" P15=K") & catParmP15.Value & (" (") & partProd.Name & (")") & Chr(10)
ostream.Close ' cierra el fichero de texto
MsgBox "PARAMETROS GENERADOS" & Chr(10) & "POR FAVOR, COMPRUEBE LOS RESULTADOS EN LA CARPETA SELECCIONADA " & chr(10)
End Sub
Can anyone help me?
Sub CATMain()
End Sub
RE: Extract properties from a .product
You can try a custom BOM...it will give you all the properties of the parts inside a CATproduct as well.
Fernando
Language="VBSCRIPT"
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim assemblyConvertor1 As CATBaseDispatch
Set assemblyConvertor1 = product1.GetItem("BillOfMaterial")
Dim arrayOfVariantOfBSTR1(7) 'change number if you have more custom columns/array...
arrayOfVariantOfBSTR1(0) = "Quantity"
arrayOfVariantOfBSTR1(1) = "Part Number"
arrayOfVariantOfBSTR1(2) = "Type"
arrayOfVariantOfBSTR1(3) = "Nomenclature"
arrayOfVariantOfBSTR1(4) = "Revision"
arrayOfVariantOfBSTR1(5) = "Mass" 'in addition of what is by default in BOM
arrayOfVariantOfBSTR1(6) = "Density" 'in addition of what is by default in BOM
arrayOfVariantOfBSTR1(7) = "Material" 'in addition of what is by default in BOM
assemblyConvertor1.SetCurrentFormat arrayOfVariantOfBSTR1
Dim arrayOfVariantOfBSTR2(1) 'change number if you have more custom columns/array...this part is for Recapitulation
arrayOfVariantOfBSTR2(0) = "Quantity"
arrayOfVariantOfBSTR2(1) = "Part Number"
assemblyConvertor1.SetSecondaryFormat arrayOfVariantOfBSTR2
assemblyConvertor1.Print "TXT", "c:\tempy\Custom_BOM.txt", product1 'change the path and name of the file according to your needs...
End Sub
Fernando
Then, I ask for it here because it seems that this forum develops programing tasks more widely. Perhaps I will have better luck.
I know that I can obtain all the parameters of a product with the standar Catia's BOM and I know how to customize it and how to script it but in fact I need a tuned BOM.
For example, the script that I published yesterday gives me the following result (from a CatPart file):
P0=K40 P1=K53,94 P2=K66,5 P5=K12 P6=K5,47 P7=K51,47 P9=K30 P11=K0 P13=K2 P15=K12 (Part1)
- The values before "K" are the parameters stored in the properties of the part
- Part 1 is the instance name of the part
What I need is to extract this datas from the whole product, for example:
P0=K50 P1=K23,94 P2=K56,5 P5=K12 P6=K6,47 P7=K71,47 P9=K20 P11=K0 P13=K2 P15=K11 (Part2)
P0=K25 P1=K93,94 P2=K64,5 P5=K11 P6=K5,89 P7=K11,47 P9=K25 P11=K0 P13=K2 P15=K12 (Part3)
....and so on... keeping this structure or format.
Do you know how to do this? Can you help me with a Catscript?
Thank you in advance.
A quick solution (which can be modified) for what you want can be found here http
I assume that you can send to a directory your product.
Fernando
This is absolutely a good alternative but I have 2 problems:
1º) I tryed several times to modify the code, in order to extract my customized properties, but I couldn't get them.
I obtain errros and erros. Could you help me a bit more?
2º) It is not a problem at all, but I see that this method doesn't give me the "Quantity" information. Not now, but I think that in a near future I'll need to add this data too.
Any suggestion?
I see that we are near the solution. I hope you can help me with it.
Check this thread out. Mid way through i walk through an example on how to create a script of this.
http://www.eng-tips.com/viewthread.cfm?qid=212167
Derek
Please, read my message of 25 Feb 09 14:36.
I need the datas in the following format:
....and so on... keeping this structure where:
I'll look there, but if you have any example code which works, please, send it to me.
¿Is it possible to do this method with a simple Catscript?
I wouldn't like to use Visual Basic.
This can be coded in VB, VBA, CATVBS etc. you may find it more difficult but not impossible in catscript & catvbs due to some of the restrictions of script.
Thank you for your links.
