Create mesh and export for use in moldflow
Using NX5.0.4.1, can I create a mesh and export it for use in moldflow? We have Advanced Simulation license.
There is not much work in UG so I would like to help out the moldflow department by creating meshes in UG.
Is UG capable of creating mid planes?
What kind of files can I use for export so that moldflow can read it in?
Thanks!
Thanks!
Productive Design Services
www.productivedesign.com
RE: Create mesh and export for use in moldflow
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Thanks for the info. It's hard to use the mid plane.
I have a wheel liner and the mold flow analyst just use the A surface of the wheel liner then create mid planes for the ribs. I tried to create the mid plane with different options but the result is not good. He will be doing it on mold flow instead.
Best Regards
Hudson
www.jamb.com.au
