Solidworks Vault and Fasteners
I've been having trouble with solidworks putting the wrong fasteners in assemblies after you check them out. This only happens when another user check out an assembly. Does anyone know how to set the vault up to where this doesn't happen?
RE: Solidworks Vault and Fasteners
I don't check yours out.
Another user checks them out, then you see the problem...or they do?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
While I know it's frowned upon to do this...
Why are you checking in your fasteners? More often than not, fasteners aren't revision controlled and don't need to be locked down. In a multi-user environment, the toolbox should reside on a network drive, accessible by all. Yes, you can assign P/N's to the fasteners as needed. This may be part of the issue you're seeing, actually. Are you using a network toolbox?
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
Yes its when someone other than the original creator of the assembly checks an asembley out do we get this problem. And thoese picturer ours doesn't look like that.
Then you're probably using local installs of toolbox, which will contribute to your problem. You'll need to convert to a network toobox setup.
My Blog
TravisCraig,
When the toolbox is pathed through network using the VaultAdmin, it displays like that.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
So from what it sounds like you always have to be connected to the vault to keep the fasteners stright. Right?
What if you use a home use license?
If you check something out work on it with you home use license disconnected form the vault and then connect to the vault to check it back in will the vault sync the files to keep the problem form reacurring
