Allowable Piping Load on Rotating Machinery Nozzles
I have a question regarding allowable piping load on Rotating Machinery Nozzles
INTERPRETATION OF PIP RESE003 ALLOWABLE PIPING LOADS ON ROTATING MACHINERY NOZZLES
For a Vital or Sensitive Rotating Machine the manufacturer recommended maximum allowable Forces on inlet nozzle are as follows
Fy = 1420 Lbs
Fz = 1130 Lbs
Fx = 570 Lbs
Maximum allowable Moments on inlet nozzle are as follows
My = 1420 Ft-Lbs
Mz = 1420 Ft- Lbs
Mx = 2830 Ft-Lbs
Recently we replaced the Expansion Joint in the inlet of this machine and we are trying to interpret PIP RESE002 for maximum allowable forces and moments at the inlet nozzle of this machine.
As per PIP RESE002 ( 5.2.2 Which states that a maximum of 50% of the industry allowable nozzle loads shall be used during the piping layout and system design stage due to the difficulty in accurately predicting piping loads and the probability of installation errors)the maximum allowable nozzle load should be 50% at the design stage of the Piping Design in order to take care of difficulty in accurately predicting piping loads and probability of Installation errors, so if we are using a software like Caesar II for pipe stress analysis then we should use 50% of the forces and moments as "Input" to this program therefore
The values of forces will be as follows
Fy = 710 Lbs
Fz = 565 Lbs
Fx = 285 Lbs
And values of moments should be
My = 710 Ft-Lbs
Mz = 710 Ft- Lbs
Mx = 1415 Ft-Lbs
The expansion joint should be designed based on these values
Now after the machine is installed in the field the allowable nozzle load is 100 % ( PIP RESE002 5.2.6 Which states Actual total loading - final field loading of nozzles permitted up to 100% of the allowable nozzle load - as adjusted for MTBR achievement )as recommended by the machine manufacturer i.e.
Maximum allowable Forces on inlet nozzle are as follows
Fy = 1420 Lbs
Fz = 1130 Lbs
Fx = 570 Lbs
My = 1420 Ft-Lbs
Mz = 1420 Ft- Lbs
Mx = 2830 Ft-Lbs
Let me know if this is the correct interpretation of PIP RESE002
Thanks a lot
Fy = 1420 Lbs
Fz = 1130 Lbs
Fx = 570 Lbs
My = 1420 Ft-Lbs
Mz = 1420 Ft- Lbs
Mx = 2830 Ft-Lbs
Fy = 710 Lbs
Fz = 565 Lbs
Fx = 285 Lbs
My = 710 Ft-Lbs
Mz = 710 Ft- Lbs
Mx = 1415 Ft-Lbs
Fy = 1420 Lbs
Fz = 1130 Lbs
Fx = 570 Lbs
My = 1420 Ft-Lbs
Mz = 1420 Ft- Lbs
Mx = 2830 Ft-Lbs
Thanks a lot
RE: Allowable Piping Load on Rotating Machinery Nozzles
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Like we don't have enough APIs, CFR, ASTMs, ASMEs, MMSs, RPs, GEEZs.
Patricia Lougheed
I think I should write some up and sell them.
Not recognized by ANSI.
"The Good Engineering Practice(s)" adopted by many
Reputable Design, Engineering, Fabrication, Consultation Entities as their internal norms
paving way to help evolution of codes and standards.
Best Regards
Qalander(Chem)
Reputable Design, Engineering, Fabrication, Consultation Entities" who have adopted these documents "as their internal norms" will be able to help.
Patricia Lougheed
I must say that your viewpoint also carries Value and Weightage indeed!
Since these 'isolated' although good practices (Most usually Business secret/least shared info) can not obtain a Consensus level to become
A Benchmark/ Frame of Reference for Code/standard.
Best Regards
Qalander(Chem)
The simple answer is that your interpretation is completely wrong. Those forces and moments are not inputs into Caesar, they are the values that you need to be checking your Caesar results against at the equipment flange. PIP generally references other specs, like API-610, for the actual allowables.
If you have values on the drawings from the vendor, then those are your starting point. Now, determination of the Vital/Essential needs to be driven by your client - in my experience with Shell, the 50% allowable systems are usually limited to very high dollar unspared compressors. I don't usually see it for a normal spared pump scenario.
Edward L. Klein
Pipe Stress Engineer
Houston, Texas
"All the world is a Spring"
All opinions expressed here are my own and not my company's.
publiccommercial "company standard". Not really useful, unless your company, or client doesn't have a set of their own already and need something quick out of a box.Enbridge sells their standards,
http://w
Those would be much better for a pipeline company.
All..
There have been other discussions about nozzle loads in these fora..
http://www
http://www.eng-tips.com/viewthread.cfm?qid=75687
I think it is accurate to say that, aside from WRC 107/297 evaluations of pressure vessel nozzles, all else is a game between the equipment suppliers and the engineers/owners.
I also think that the PIP guidleines are not binding in the case desribed above.
Mr. John Breen has extensive experience and knowledge in this area and it would be very helpful to get his input
-MJC
