Steel beam flange notch reinforcement
I need to cut a 3 1/4" x 24" long notch out of the bottom flange of an existing W24 beam to install a piece of equipment. I cannot find any reference material describing how to handle the reinforcement. Does anyone know of sources or methods? Thank you.
RE: Steel beam flange notch reinforcement
corners of the notch should have a nice radius, something like 1" even if it makes the notch longer ('cause they've been cut sharp).
reinforcing with a welded plate that's longer than the notch does relieve the stress concentration at the notch
