Traverse Assembly - Add Custom Property
I am trying to write what I thought would be an easy API script. All I want it to do is to traverse all parts in an assembly and add some custom properties to them. I have managed to get it done with one method, but that way flashes each part across teh screen. I would prefer if it did not do that. I have written this, and it traverses the assembly and can debug print, each child. But I cannot get it to add the property.
What am I missing. Thank you in advance for you help and time.
______________________________________________
Sub Main()
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim refModel        As SldWorks.ModelDoc2
Dim CustPM          As SldWorks.CustomPropertyManager
Dim nErrors         As Long
Dim nwarnings       As Long
Dim ChildName       As String
Dim AddProp         As String
Dim vChild          As Variant
Dim vParent         As Variant
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
vParent = swModel.GetPathName
Debug.Print vParent
vChild = swApp.GetDocumentDependencies2(vParent, True, False, False)
For i = 1 To (UBound(vChild)) Step 2
Debug.Print vChild(i)
Set refModel = swApp.OpenDoc6(vChild(i), swDocPART, swOpenDocOptions_Silent, "", nErrors, nwarnings)
Set CustPM = refModel.Extension.CustomPropertyManager("")
AddProp = CustPM.Add2("My test", swCustomInfoText, "Blah")
Next i
End Sub
RE: Traverse Assembly - Add Custom Property
Nevermind...I went and had lunch and when I came back. the code seems to work just fine.
