Swivel Type Flange (Collar) Nuts
Does anyone know if collar nuts with a swivel washer are acceptable to use for B16.5 flange bolting applications?
I have an application where a blind flange is bolted on and off a mating flange several times per day and the blind flange is starting to wear at the nut bearing surface. I want to use swivel nuts to reduce the wear on the blind flange, however B16.5 recommends the use of B18.2.2 for determining dimensional requirements for nuts. Collar nuts aren't specifically dealt with in B18.2.2, nor are they specifically disallowed. Does anyone have any thoughts as to why a swivel nut wouldn't be allowed?
RE: Swivel Type Flange (Collar) Nuts
The Swivel Nut doesn't meet any bolting standards. As the Swivel NUt asembly could allow some angularity in the bolted assembly it presents an intgrity problem.
http
http://www.nationalboard.org/Index.aspx?pageID=205
http://www.nationalboard.org/Index.aspx?pageID=197
Regards, Jogn
