Xd for leroy sommer generator
I´ll like to know the Xd for a leroy sommer generator, i thought that was 15 but i don´t remmenber
RE: Xd for leroy sommer generator
generator is 300kw and 400 volts
gaux
I think that your memory is failing you, Xd for an alternator of this size would be in the region of 2.85
X'd about 0.18
X"d about 0.13
Careful guys!
Xd is sychronous reactance - and 150% - 300% is of the right order for this size.
Xd' is transient reactance, and 15% - 30% is the sort of value you see
Xd" is subtransient reactance, and can be say 5 - 20%
It all depends on the exact design and winding configuration
Xd' and Xd" are the ones you need most, for fault level calculations etc.
Why not ask Leroy Somer?  www.leroy-somer.com
You will need the frame size and serial number from the nameplate
thanks at the end i find it, and it´s x´´d is 9,3, Xd 327 and X´d is 15,5, and yes, i go through your link and find on leroy somer....
thanks very much
Nice to have feed back.  Good luck
