Reciprocating Compressor VFD
Hi Guys,
I am here in Korea with a high pressure diaphragm pump (1,500 psi) driven from an ABB ACS510/550. The problem is it won't pull away under load (800 psi is no problem). We had the ABB rep in to solve a low speed excessive curent problem, I'm told he changed the V/F curve to linear but I suspect we need something more. The manual and display are in Korean and I don't seem able to download an English version.
If someone could suggest a fix and perhaps an English parameter listing that would be a great help.
Thanks in advance
Roy
Thanks in advance
Roy
RE: Reciprocating Compressor VFD
Does it have an unloader?
Keith Cress
1. Are you running the drive in sensorless vector or scalar mode?
2. Is there any gearing or belt/pulleys between the motor and the compressor?
3. You can certainly download an Instruction Manual in English from the ABB website.
Let me know on the above
No it doesn't have an unloader just a gearbox with a crank and 3 recipricating diaphragms Lewa is the brand, new installation. We have e-mailed Lewa but no response yet
Thanks for the response
Roy
If you cannot find a local contact, call 800.752.0696 option 1, then option 1, and ask for contact information in your area.
Does the cable length 50 meters and lack of Line/Load reactors have any effect on starting torque?
Roy
