Shear wall -beam connections
I'm trying to design a five story apartment building with a RC moment frame for the vertical load and an RC shear wall for the lateral loads. It has one and and two way slabs on beams. Is it a bad practice to have the beams frame into the shear wall (both in the plane of the wall and perpendicular to it)? If it is ok then where can I find rebar details for the connection?
RE: Shear wall -beam connections
Did you intend to post a picture?  Your link goes to the reply screen.
I don't know of an argument against framing beams into walls.  It is done all the time.
No, I made a mistake, there is no picture
Just make sure the shearwall steel is continuous through the wall.  Might get kinda tight, so a good detail of placement will be needed.  In plane condition will be the worst case here.
Mike McCann
MMC Engineering
