Simulation of polarization on internal of tanks- Cathodic Protection
I`m working on a small research related to internal cathodic protection of oil-water separator tanks(on-shore) operating under higher temperatures(~80 C). Anybody has some hint on how to simulate(simplified but 3D, in matlab for example) polarization spreading when using impressed current protection?
Thanks in advance,
Cleber
Thanks in advance,
Cleber
RE: Simulation of polarization on internal of tanks- Cathodic Protection
Where are you doing your research and will it be published?
David
For researching 'polarisation spreading', I can only recommend producing a simulated vessel bottom with a simulated oil water mixture and simply mapping the potential with a reference electrode probe.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
http://www.beasy.com/
they have developed a software for CP simulation.
s
Corrosion Prevention & Corrosion Control
