How do I specify the spacing around an arc?
If I have a pattern of welds around a circular edge (say fillet welds) how do I define the spacing? For example I have 4 25mm welds around a 74mm diameter. Do I measure the circular arc length as the pitch and put 25-58.1 on the weld symbol? Or is there is different way to define this?
Jeff
Jeff
RE: How do I specify the spacing around an arc?
Dik
Jeff
