relative permeability using JBN method
can anyone help me solve this problem?
i have PVI= .339 and oil produced= .383 and delta P= 9.02psi for the first run and then i have values for every min.
i also know:
q= 100cc/hr
irr water saturation is 0.12
length= 55 cm
diameter= 5 cm
porosity= 30%
initial delta P= 10psi
k abs= 3.4Darcy
viscosity oil and water are 108 and 1 cP
effective k of oil @ Swirr is 3.1 darcy
i have to find oil-water relative permeability as a function of water saturation. can someone help me get this started for the first run so i can plot the curves using excel? thanks a lot, ryan
i also know:
q= 100cc/hr
length= 55 cm
diameter= 5 cm
porosity= 30%
k abs= 3.4Darcy
