Can CFD do this???
Can CFD do this???
Can CFD do this???
Here is a simplified scenerio:
Submerge a cup in a large tub of water. Let the air out and flip it upside down. Attach a string to the closed bottom (now top). Apply a sinusoidal movement to the string from surface to simulate wave under a boat.
I am interested in the general dynamics: cup movement, fluid flow, force on line, cavitation.
Is this a reasonable request for a CFD program given the movement?  Whast would be a good package to look into?
Thanks for any input.
RE: Can CFD do this???
Interesting scenario. That is a real multiphysics question. For this I would suggest looking into Comsol Multiphysics. I have used it quite often for the past few months for FSI.
I have seen it used for mixing of a highly viscous oil and water, which would be similar to your problem by replacing the oil with air.
Good luck,
peace
Fe
From the little I know about CFD, I think the 2 phases will be problematic.  You might want to x-ref this thread to the CFD forum.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
I don't mind if the analysis cuts the rope so everything is under water. I just need the sin input.
If no cavitation is needed, it becomes a VOF task.
--It boils down to simple math--
