Hole Wizard mods
Hole Wizard mods
in SW2006.
I'd like to change the HoleWizard drawing callout for tapped holes. For instance, instead of 1/4-20 Tapped Hole, we'd like 1/4-20 Tap (the omitted part of SW's default note is a given)
Also, in the model itself, how can we add a default c'sink angle & diameter ("near" and "far side" when tapping thru) to the HW so that these values don't have to be entered in every occurance?
For instance, the 1/4-20 would have a c'sink angle of 82deg (ANSI std) and .265625 (1/64 over nominal) I realize that other sizes will need differing appropriate diameters.
I've read numerous old threads regarding adding to or modifying the *.mdb files that HW uses....but what <u>program</u> is used to open the file(s), and is this the correct file to be changing for this purpose?
RE: Hole Wizard mods
-handleman, CSWP (The new, easy test)
Bradley
SolidWorks Pro 2009 x64, SP2.0
PDMWorks Workgroup, SolidWorks BOM,
HP xw8600,
64-bit Windows Vista Business
Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB,
nVidia Quadro FX 4600 Driver 7.15.11.6956
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
http:/
Flores
