Flexible Impeller
Flexible Impeller
I have a customer destroying nitrile impellers almost every week. We draw fluid from a roughly 10' diameter tank through a 1" line into the 3/4 port on the pump. The tank is within 20 feet of the pump. Any ideas on the cause and hopefully a solution?
RE: Flexible Impeller
Seriously, you are giving us no information on the pump, rpm's, fluid, solids, anything... Throw us a bone please!
Give some info and you might get help.
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
Could it be cavitation?
So as long as there is a guarantee of flooded suction, the problem lies on some flow obstruction I guess.
As a side comment, I once had a centrifugal pump impeller destroyed couple times due to cavitation (much larger that what you have). Took us about a week to find the issue. Bugs!!! Bugs falling into the tank were sucked into the lines and a particular type of beetle always plugged it. It had a pretty hard shell.
have you a filter upstream of the pump?
What is the type of impeller of the pump, is it a submersible waste water pump?
for waste water fluids, you have typically three or four type of impellers (closed with 3 or 4 vanes, open, open similar to screw for example).
depending on the content in fiber, sand, solid content etc you need to go with the right impeller type and metallurgy.
Mike Halloran
Pembroke Pines, FL, USA
Johnny Pellin
Ted
This impeller would probably not respond well if it was spun backwards. Is there any chance that this could be happening?
Johnny Pellin
Ted
I would agree with Johnny Pellin - any chance of the pump running backwards at any stage and rubber is very tolerant to cavitation damage?
