Bearing alloy casting.
I am trying to find a better material for the melting cup my company is using when melting and casting bearing alloy on small thrust pads. They have previously used TP316 steel, but lately they have experienced severe material failure at the bottom of the melting cup. The bearing alloy is tin-based, type Tegostar. The alloy is heated to a temperature of 540-550 degr. Celsius.
Any suggestions?
Any suggestions?
RE: Bearing alloy casting.
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
Are yours failing from the inside? maybe just a ceramic wash on the inside would take care of things.
Plymouth Tube
