Transfer Function of actuator
Hi!!
I am trying to design a position control system based on an electromagnetic actuator. a PID controller seems like a reasonable choice for me to use but I am having problems trying to derive a transfer function for the actuator before I begin designing the controller
any help would be appreciated
thanks!
RE: Transfer Function of actuator
Its a SMAC LAL 30-015 moving coil actuator and it is driven by a current loop amplifier.
I am currently trying to measure its performance in terms of robustness. So I am running a MATLAB simulation first of the system and then comparing the results to the actual working model
The amp is a 24v , 5A dc supply
The actuator has a 15mm stroke and peak force of 14.5N
K*omega^2/(s*(s^2+2*zeta*omega*s+omega^2)
The second order part would represents the mass in the coil and omega should has a very high frequency. If there isn't much friction then the damping factor, zeta, will be quite low, perhaps 0.1 or smaller. Let use know what you think.
Mechanically, the actuator follows Newton's First Law of Motion, F = M x a
If you want a "Killer" amplifier to drive the actuator, look at a LA-400 amplifier from Varedan Technologies
www.varedan.com
