Viewing jt file containing tif image
I have a part file created in NX3. It contains a raster image. The raster image is a tif file that was added to the part using: View/Visualization/Raster Image.
In NX, the part looks fine. After the part has been tessellated and is viewed in
Vis the .tif image is not viewable.
See example snapshots in attached file.
1. Is there any way to view the tesselated file in Vis showing the tif image?
2. Are there any settings in the tesselator that may need to be set to enable viewing
of the tif?
3. Is there a different process to follow in the creation of this file that will
enable viewing of the tif in Vis?
of the tif?
