standard pipe wall thicknesses
I am looking for a list of standard pipe sizes wall thickness's in the range of 15mm to 200mm for carbon steel pipe, or other common pipe material used for heating/cooling water applications. It would be useful to know when using an ultrasonic flow meter. need wall thicknesses in mm
RE: standard pipe wall thicknesses
Can you google? Just type in 'pipe wall thickness'.
Cheers,
gr2vessels
yes but cant seem to find a list in metric, all in inches. could convert but thought somebody might have it handy or know where to point me for it
Pipe is made in inches worldwide, that way all flanges and fitting fit everywhere.  You can make a soft metric conversion easily yourself.
cheers
B36.10 has pipe sizes in both metric and imperial
The "Pipe Trades Handbook" published by IPT has dimensions in both Imperial & metric.
IFRs - I've hit British Standard flanges & pipe that sure didn't match up with anything stocked by suppliers here in Canada.
