Batch capabilities
Batch capabilities
Batch capabilities
I need to be able to import a lot of .$2k files into SAP (they are slightly different versions of the same .SDB model that I modified using an external routine).
Do I have to import the $2k files one by one into SAP to create the SDB model? The batch command does not seem to handle $2k files.
Does anyone know of a way to use the command lines to do that? I couldn't find commands for SAP except to open an SDB file, run the analysis and delete and close the file. Has anything been added to that?
I saw an old thread mentioning that such capabilities were expected to be added to SAP2000 v9, 4 years ago. But I still can't find a way to do it.
Thank you for your insight,
aa81
