Pad multiple shapes together to creat an Airfoil
Does anyone know how to pad multiple shapes that have different dimensions in order to make one solid part? I'm trying to create a wing with different airfoils along the span of the wing but I do not know how to connect all the sketches to make a solid streamline piece. Basically the root will have a different airfoil than the tip. Can anyone help me out here? I hope my question makes sense. Thanks!
(i provided a rough sketch as an attachment link)
RE: Pad multiple shapes together to creat an Airfoil
Some info here:
http://www.youtube.com/watch?v=skDq_eBpdFQ
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
I'm modeling an experimental aircraft right now and I'm using surfaces for most of the stuff I'm doing.
If you need a more-or-less quick and dirty result you can use simpler methods. (For example, maybe you need to mock up some wing parts for a proposal package: the wing would be a simple representation around which you would model proposed equipment) For this sort of thing the multi-section solid function works well.
To do this, create planes at stations along the airfoil, and create a sketch on each plane representing the cross section at that station. (Then check the help docs about the Multi-Sections Solid command)
The level of complexity and accuracy you need will determine which method (or combination) is appropriate for you.
Cheers,
Mark
I imported points for an airfoil and now the problem i'm having is i want to make it to a solid piece but when I go to sketcher mode, I can not use the spline function since it will not let me click on the points. How can I connect the points to form a close body to form a solid part? I might start a new thread for this. Thanks all you guys!
Forever Young.....
