Removal of a load bearing wall
I want to remove part of a load bearing wall (11 ft span) in a single story home (1969). The roof is a purlin roof and the purlin braces do not run into this wall. The wall supports ceiling joists (15 foot span on one side and 10 on the other).
I need to know two things, first, the size of the header required..although I think I have that part. More importantly, where the jack stud hits the floor, I need to know what to do.
The house is built on 4X6 beams spaced 4 ft apart. These beams run parallel to the wall beaing removed. There are pier blocks every 6 ft under the beams. The sub floor (2x6 t&g) rest directly on the beams. The jack stud under the header will fall 6 inches to the side of a beam and 2 ft along the beam from a pier.
Is this sufficient to handle this load which should be minimal or is an additional support under the house required?
RE: Removal of a load bearing wall
roger
