Configuration Specific Dimensions not working
Hi All,
Just having an issue with one of my parts. There are 3 circular tooth patterns that are each controlled with their own radius dimension. I have 3 versions of the part which each have different radius values. For some reason when I adjust the dimension in 1 configuration, it's being applied to the other configurations as well.
I'm not using derived configurations, and I've set the configuration option in the modify dimension box to "this configuration only". I'm currently upgrading to SP2.1 for 2009 in the hopes this fixes the issue but if not where can I go from here?
Thanks in advance.
Thanks in advance.
60% of the time, it works every time.
RE: Configuration Specific Dimensions not working
