Hatch Design
Hatch Design
Hatch Design
I tried starting this thread in the Gear Forum with no response so I will try this one... I am design a hatch the locks with a mechanism similar to a bank vault, i.e. having a centrally located hand wheel which when turned advances a series of radial pins outward.  I am not sure how the gear arrangement inside the hatch should be designed (if it is gears or some other mechanism).  A series of sample photos from the twenties can be viewed from the following link.  It shows very well what I am trying to descibe above, but on a larger scale.
http://www.clev.frb.org/bicenten/door.htm
If anyone has any insight or links to information, regardless of how general, all would be appreciated.
RE: Hatch Design
You don't need gearing if a diaphragm style mechanism would give you enough pin movement.
RE: Hatch Design
There are many ways to design a mechanism that will do this.  You can use a combination of any of the following: gears, pins, levers, links, bell cranks, threads, cams.  One important consideration is whether or not the pins need to exert any force.  In other words - are they acting just as latches, or are they also drawing the hatch cover into close contact with the opening?  pdr@baymachinedesign.com
RE: Hatch Design
Thanks ornery norsk & Philrock.
O.N.:  I have not seen anything like a "diaphragm style mechanism" unless it is called something else.  Do you have any details?
Philrock: The pins seen minimal force as they move outward.  They will be under signicant shear loasding once the hatch comes under pressure.
I realize that there is a great number of ways to approach this, but I was curious if anyone had any details on the inner workings of the specific design on the web link. I am basically doing a little 'legwork' now on diffenent design approaches already available without having to reinvent the wheel.
RE: Hatch Design
There are a few companies I am familiar with that manufacture such hatches for the marine industry.  They are Centex, Railway Specialties Corp., and Juniper Industries. Check out their diagrams, I think most are just variations on 4 bar linkages .
http://www.railwayspec.com/
http://www.juniperind.com/
