Drive dimension using custom property
I know this has been up here before, but i can't figure out how i works.
I want to be able to specify a value linked to a dimension using custom property. My plan is then to control dimensions in several parts using task schedular thru custom property.
Thanks!
Thanks!
RE: Drive dimension using custom property
-handleman, CSWP (The new, easy test)
What do i write in equation? And wath do I write in custom property?
MyCustomPropertyThatICantFigurOutHowToLinkIntoADaggumEquation
then you should type in
"MyCustomPropertyThatICantFigurOutHowToLinkIntoADaggumEquation"
Alternately, there should be a little "Down arrow" looking button at the bottom of the equation editing dialog. Click that button and hunt down the property you want.
One more question thou... The parts won't rebuild using update in task scheduler after changing the value in custom property. Nor will them update using rebuild in assembly. Do I have to open them and rebuild them one at the time?
That'sonehellofapropertyname!
Astarforyou! ;)
- - -Updraft
Sub main()
Dim wait As Double
wait = Timer
Application.SldWorks.ActiveDoc.ForceRebuild3 (False)
MsgBox "Rebuild time: " & Timer - wait & "s"
End Sub
A=50
B=100
C=150 etc.
make sure there are no empty lines or you'll get error
SolidWorks will automatically add "Quotes" around the Variables A, B, C
When you add a dimension in your sketch you can use the Link Value... function from the drop down shown to the right of the dimension value and link to the "A" variable which will show as $VAR: A
This is a more powerful method than using equations because any dimension linked to the A Value can be modified to change the variable.
This method of defining the Variable before linking a dimension allows the value to be modified from the Equations List or from any linked dimension.
Linked values can be created on-the-fly when modifying a dimension and the dimension name D# will be replaced by the Linked Value text. If D1@Sketch1 is right clicked and Link Value is selected the Variable you enter "DRAFT" will replace D1 so the dimension name is DRAFT@Sketch1
Entering the Link Value name after the dimension is created will show a link symbol next to an equation in the list and will prevent you from modifying the Equation.
If you set an equation D1@Sketch1 = "Draft" will only let the dimension be modified from the equations dialog. Or in another sketch you linked "D1@Sketch3" = "D1@Sketch1" you could only modify the Driving Dimension. With Linked values either dimension could be changed and both would update to the new value.
Michael
