SCALE - CHANGING DIMENSIONS
If you create a part model complete with dimensions...
when you add a scale to that model, the dimensions stay as the dimensions before the scale!
Is there a way to change the dimensions with the scale?
RE: SCALE - CHANGING DIMENSIONS
http
Dim a 3D model is different than dim a 2D dwg in ACAD.
Model the part to 1/1 scale, then add the views to the drawing to required scale. Want a different dim, change the 3D model.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
