air system options
air system options
air system options
for long vertical distance (about 40 feet between evap-cond) what would be the best system for air conditioning. this are small one bed apartments and there in not much room for central handlers.
RE: air system options
Split Air Conditioning systems, but not the cheap Chinese models...
Cheers,
gr2vessels
Chilled water system, perhaps?  Water is chilled at a central unit and sent to local coils.
40ft is too high for splits. You may have to bring down the condenser by 20ft. What is the problem with window A/Cs? TheTick's suggestion can be a good alternative.
