Multi-(sp)line Perimeter of a UV Lofted Surface
I created a UV lofted surface with spline U's and straight
wire V's. No problem. Next, I need to create a 'cut-out'
of that surface that is irregularly shaped using splines,
fillets and line wires. I can't use 'amplane' because I
need the surface to undulating. I can't use UV loft with
the closed set of wires because I have too many wires.
Basically, I need a complex curvilinear surface with a
goofy perimeter. I can get the cuvilinear surface but not
the perimeter.
Thanks if anyone has any suggestions. I would appreciate
it.
NancyL
nyc
the perimeter.
it.
NancyL
nyc
RE: Multi-(sp)line Perimeter of a UV Lofted Surface
using the intersect surface command to cut away the portion
of the surface I wanted to remain. However, I am using some
tight fillets in the polyline which Mech Desktop doesn't
seem to like.
Thanks again.
NancyL
