Temperature Sensor
Temperature Sensor
Hi
I need to measure the temperature of fluid Viscor(similar properties to gasoline) but I'm not quite sure what type of sensor is suitable for my application
based on their experience can you suggest me any brand of temperature sensor?
with the following characterisitics
* Range Temperature to sense: 0 to 50 centigrade
* Output Sensor: 0-5V
Thanks in advance.
Thanks in advance.
RE: Temperature Sensor
- operating temperature (can be higher than the desired measurement range)
- chemical tolerance (I'm guessing stainless would be fine)
- accuracy and linearity
- RF tolerance
- cost
- response time
- expected life/usage (1 time vs. 5 yrs)
The measurement range is fairly low, so there are many different options. (thermocouple, RTD, infra-red, etc.) There are literally 100's of options so you need to better define the constraints.
ISZ
