Ansys v12 Parallel Processing Enhancements
Hello All,
I just met with an inside Ansys sales person and he mentioned that the new version of Ansys v12 along with the newest version of the Intel processor will allow for parallel processing benifits beyond 8 processors.
According to the Ansys white paper "Obtaining Optimal Performance in ANSYS 11.0" available on the Ansys support site at the following link:
http:/ /www1.ansy s.com/cust omer/conte nt/whitepa pers/Obtai ning%20Opt imal%20Per formance%2 0in%20ANSY S%2011%20- %20White%2 0Paper.pdf
the benifits of parallel processing typically top out for Ansys FEA at 8 processors. It attributes this to portions of the code that are still single threaded. However, according to this sales person the new version of Ansys and the newest chip from Intel will allow parallel processing benifits to be extended way beyond 8 processors. When I asked further he stated that Ansys has partnered with Intel and the new architecture allows for more portions of the FEA code to be "crunhed" in parallel. He continued by stating that the parallel benifits will be on par with CFX, which apparently has always benifited from multiple processors beyond 8.
I was just curious if anyone else has heard this and if so could you point me to a website that may give some more information. We are looking to upgrade our number crunching computer.
steve
http:/
steve
RE: Ansys v12 Parallel Processing Enhancements
http://www1.ansys.com/customer/
I suppose you must be registered as a "beta tester user" in order to be allowed for such a thing like a beta download. A "common" user such as me is not allowed to dowload v.12 beta, there is not even the link.
regards
Maybe I'm getting mixed up. I know they released a beta of CFX and Fluent 12, but maybe not ANSYS V12.
Sorry
According to the presentation, the AMD chip is more scalable when more and more processors are used to solve the problem. However, the AMD chips are slower at solving the problem than the Intel chips. Therefore, when taking all into consideration pertaining to problems solving across 8 processors or more the two chip designs, Intel vs. AMD, are similar. However, that only applies to problems distributed accross several processors. For signle processor problems Intel is far better.
From what I understood, when Intel comes out with their new chip not only will the chip crunch the numbers faster, but it will have much improved scalability over multiple processors. Thereby making the Intel chip the better choice for multi-processor solutions.
Hope this helps,
Steve
What you report here throws more light upon "voices" I already heard about that.
It seems to confirm that AMD still has a gap to fill before it can claim to be "the most powerful PC processor", at least as regards floating-point operations, a field where it is well-known Intel is the leader, at least for "PC-workstations" processors (it's a pity Digital Alpha processors have been discontinued...).
Also, this is coherent with the fact that AMD has designed its architecture from the start keeping in mind two main factors: integer operation and scalability. Whether float-operation was a real disaster at the start, nowadays thing have evolved positively, but the gap from Intel seems however hard to be completely overcome...
Bearing in mind that Ansys charges for a separate license beyond two "processors", IMHO for a standard "non-parallel processing" license of Ansys the best choice in PC is still Intel by far.
The Xeon version is due out sometime Q2 2009 I believe.
