Factors of Safety for Retaining Wall Design
Typically when we receive friction values and passive pressures from the geotechnical engineer they will either specify whether the values are ultimate or have a FS of 1.5. Assuming the values have the factor of safety in it, when you are designing the footing for sliding would you increase the values to ultimate and then design the footing so your FS is 1.5 or keep them as they are and have the force = resistance (still have a FS of 1.5 b/c the values given are factored down) or keep the values as is and design the footing so the FS is 1.5 on the output... Hope that makes sense! Thanks
RE: Factors of Safety for Retaining Wall Design
