Nickel Aluminium Bronze and Inconel
Would there be any reasons not to use nickel aluminium bronze and inconel in the same environment.
RE: Nickel Aluminium Bronze and Inconel
In what sense: electrically connected?  What environment?  Coupled in seawater, the NAB will be the anode and will suffer enhanced corrosion.  How much depends on many additional factors.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
NAB has pretty good corrosion resistance, but a couple with 625 would drive selective dealloying.  If they are not coupled it should be fine.
Plymouth Tube
They would be coupled together to form a valve body and seal and would be in contact with seawater.
We normally would be using Monel 400 but have no stock. We need to find a replacement material fast and have 625 in stock.
I would not suggest that 625 has good enough crevice corrosion resistance for a seawater valve seat.  Try looking for one of "C" type alloys.
Plymouth Tube
