dcp
dcp
How do i convert my DCP readings to AASTO?
RE: dcp
RE: dcp
RE: dcp
RE: dcp
There are many such correlations around as well as methods to convert DCP to CBR.
In my opinion, such correlations, are only useful as toilet paper.
The DCP is extremely sensitive to moisture changes in the material. You can have 2 instances of an identical material that are compacted to the same degree but at completely different moisture contents. These correlations will give you a huge variation in the bearing capacity of that material.
You can get reasonable results in clean sands but in all other soils the DCP is better off being used as an investigative tool to discern the actual depth of strata changes that were detected in a borehole.
Sorry for the rant
Michael
RE: dcp
RE: dcp
RE: dcp
RE: dcp
RE: dcp
RE: dcp
