Plotting a range of data
Hi everyone,
I am new to Mathcad so please bear with me.
I am trying to plot a scatter of two variables. This works fine, however when I specify a range for the two vectors it does not work. The error message stating "Value must be a scalar" in regard to the range value.
Can anyone help?
Can anyone help?
RE: Plotting a range of data
Thanks for the support.
apparently,
click on 'upload your file ..' link by Step 3 edit box
browse to your file from the resulting dialog
click upload on the dialog
on updated dialog, click on 'click here ...' link
You should then be returned to the main page and see the address of your uploaded file in the Step 3 edit box ..
and that appears to be it
I done that and the link should be included in this post.
Thanks again.
Is it Mathcad 12, 13 or 14? Just a tip, you'll get a wider audience if you post it in Mathcad 11 format as well - a lot of significant users still use that version.
Thanks"
No problem.
