Gradual contractions in pipe
  I am looking at page A-26 in Crane's manual. It shows that for pipe with a gradual contraction with an angle of convergence of between 45 and 180, we are to use Formula 4.
Formula 4 is dependant on the sine of half the angle.
If I use an angle of 180 (abrupt change in diameter) then should this correlation not be equal to Equation 2-10 on page 2-11???
This does not make sense, since Formula 4 is divided by Beta ^ 4, there can't be legitimacy here?? They must equal if the wall angle = 180!!
Please explain this to me.
  Thank you.
RE: Gradual contractions in pipe
In my (1988) edition of Crane it seems you are referring to Formula 2 on Page A-26, and not Formula 4.
√(sin(180/2)) = √(sin(90)) = √1 = 1
Equation 2-10 gives the value for K1, which is based on the smaller pipe diameter.  Formula 2 gives the value for K2, which is based on the larger diameter.  K1 and K2 are related by  equations 2-5 and 2-11.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
But it is divided by B^4?
Or is 1/B^4 just a factor that need not be considered when comparing the two equations?
Thanks katmar
dbecker
Yes. Formula 2 is Equation 2-10 (Κ1) divided by Β4; that's what the second "=" is telling you.
Yes. You need to consider the Β4 when comparing the two equations.  Κ1 ≠ Κ2.
As katmar stated, it's because Equation 2-10 is in terms of Κ1, while Formula 2 is in terms of Κ2. (Actually this applies to all the formulas on page A-26)
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Thanks for the clarification.
Makes sense now.
