Starting time of a motor with VFD in ETAP
Hello everybody. I'm trying to run a motor starting analysis in ETAP. I think that with a VFD, power factor should be aprox. 0.95 and current needed shouldn't exceed 150% FLA, but I can't acomplish that with ETAP. I get "Failed to Start" if I limit the current beneath 350% using torque or current control. Anycase, PF is the motor model locked rotor PF.
Any idea?
Thanks in advance!
PS: I'm from Argentina, so english it isn't my native language!
Any idea?
Thanks in advance!
RE: Starting time of a motor with VFD in ETAP
Power factor at the motor and power factor at the drive input may be very different.
What are you trying to determine?
Your workaround is probably a good approximation.
With a VFD, the starting time can be nearly whatever they want.
But basically, I have never seen a VFD that would not be capable of starting a load that it was capable of running. The starting time can essentially be infinite if necessary. It's not like a Soft Starter or Autotransformer where your current increase is significantly consuming the thermal model of the motor without providing much accelerating torque. Don't forget, 150% current on a VFD is not the same as 150% current on a current controlled start model (i.e. Reactor, Autoxfmr or RVSS), because you are creating a lot more torque at 150% current with the VFD by keeping the V/Hz ration constant, essentially Locked Rotor Torque.
So if ETAP doesn't have a VFD model, try modeling it as if it is a 550% Current Limit Start from a soft starter to get the starting time. But remember that will NOT then be an accurate model for Voltage Drop etc.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Pick the current you do not want to exceed, somewhere between 100% and 150%. Then, pick the motor torque off the motor curves for that current. Use those 2 values to create new "flat line" motor curves with the same current and torque for every speed. Run the simulation using the current you picked. That should get you a reasonable simulation of the minimum starting time.
The maximum starting time can be whatever you want up to the limit of the VFD ramp time setting.
Best regards,
Mark Empson
L M Photonics Ltd
