Ground Ring
Ground Ring
Attached is a very rough sketch of a simple oneline grounding scheme of two buildings.
Building #2 is served from Building #1.
My concern is the ground ring at Building #2. The installation has the ground ring at Building #2 back to the groudn bar in the distribution panel at building #2. The bare copper conductor for the groudn ring is routed to the distribution panel and bonded to the distribution board enclosure and terminates at the ground bar. The ground ring at Building #2 is also connected into the lightning protection system for Building #2.
When i saw the bare copper ground ring bonded to the distribution board enclosure my spidey sense kicked in.
If anyone has any refernce is this is code compliant I'm all ears. I'm not looking for opinions; just want to know if it's right or wrong.
thanks.
b
thanks.
b
RE: Ground Ring
RE: Ground Ring
RE: Ground Ring
I forgot to put in the one line that incoming water pipes (which also originate at building #1) are used as the grounding electrodes for building #2.
So it's ok to have the bare coper conductor (uninsulated) for the ground ring at building #2 to be installed through the distribution board enclosure? I would have thought it would need to be insulated when in the distribution board enclosure.
thanks
b
RE: Ground Ring
RE: Ground Ring
RE: Ground Ring
