Inverted cone roofs for API-650
I have a client that is looking for an inverted cone roof on a 30 foot diameter tank. Does API recognize this type of installation? Are there issues with type of installation?
Best Regards,
Michigander
RE: Inverted cone roofs for API-650
Assuming you mean a cone down roof where the center is lower than the edge:
API does not recognize this type of roof.
What do you do with water/snow/ice that accumulates?
Should not be too hard to design, look out for additional forces on the upper tank shell.
IFRs is right.  API-650 does not recognize this type of roof, but it does not prohibit such a roof.  You are on your own with regard to design procedures of the membrane roof and compression ring.
Joe Tank
I think although not directly but in a way;
the open top floating roof type tank's roof(external)
has somewhat inverted cone like design
although not with a very sharp slope from side to centre to appear like an inverted cone.
Best Regards
Qalander(Chem)
The membrane analysis similar to that in API-620 should be useful for the design.
Thanks so much for all of the insights!
Best Regards,
MIchignader
