reset the Information window position?
Hello, for a while we were using dual monitors and just went back to using one. The only issue I've had so far is that the information window in UG is displaying off screen. To correct this, in most cases, you only need to hit "Alt" then use the arrow keys to pick "move" and move it where ever you want it.
The information window in UG doesn't have this option. Do you know of a way to move it into view? Re-installing a second monitor is out of the question at the moment. I tried messing with the nvidia control panel to make sure the second monitor is shut off, which it is, but the info window is still off screen.
Any ideas? Is there a function in UG to do this?
thanks
steve
RE: reset the Information window position?
Go to...
Preferences -> User Interface...
...and select the 'Layout' tab.  In the section titled 'Settings', select the 'Reset Window Position'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
thank you very much for the tip, John. Worked like a charm :)
it's very much appreciated.
steve
